My Evinrude 25 (1990) would start to run then die over and over. I replaced the fuel pump as the diaphragm return spring had collapsed. No Good still did it.
Put in a carb kit and cleaned out the carb. Replaced plugs, fuel lines,and bulb and hoses.No luck. Gave up and took it to the repair shop. $400+ dollars later with a new power pack it runs great.
Gave it a trial run yasterday and it ran strong. The fishing was excellant.
Take care and thanks for the help.
TJ
TJ
