Johnson 55EL78S 55hp Type IV Carbs<br />Currently both carbs are fixed jets, <br />low speed and high speed. No med range<br />jet. Is it possible to make the idle<br />speed jets adjustable without replacing <br />the carbs?<br /><br />Smitty
Idles good in neutral, but not in gear. If I speed the idle up in gear it runs away in neutral. <br />Idles way too fast with the ears on. It just seems to need a little tweaking. Carbs are clean with good compression. New plugs.<br /><br />Smitty
