fitment question ? help
jeesybubba1
I have an 89 30hp will an 83 25hp lowerunit fit my motor both johnsons thanks in advance
tx1961whaler
Re: fitment question ? help
You can go to the electronic parts catalog at http://shop2.evinrude.com and pull up the diagrams for both of the motors and compare the lower end part numbers. If they have the same drive shaft numbers, then check the housing numbers. If they match, you're probably OK
