Fishmark 320
mudminna
Will not go to 'normal' screen, just shows 'loading' message in lower left corner when powered on. Any one else had this happen?
Barnacle_Bill
Re: Fishmark 320
Try resetting it.
Turn the unit off.
Press and hold the zin and zout buttons at the same time
Press and hold pwr button
Release both buttons when unit beeps
mudminna
Re: Fishmark 320
Yep,
Tried soft reset and hard reset (no beep), unit doesn't respond.
Checked cables and fuse, checked battery - all good.
Have had it for a just under 2yrs, this started intermittently couple months ago, worked great up until then. Not sure about next steps, could get another one and try using same transducer, replace with a more expensive unit or just try my luck with an el cheapo if they're only going to last a yr or 2?????
Thx Capt....
