Fishing line deflector?
keithc81
There is a spacer with an offset ridge in it and can't tell which way that goes and if the deflector ring should be on the drive side or prop side of that ridge? Is it supposed fit tight to something or move around loosely on the spacer?
Thanks
Ciera2450
Re: Fishing line deflector?
On my 280 the Line cutter was welded to the spacer. It was all one piece. Unsure if yours is like that.
It goes behind the prop. Just over top of the zinc ring.
keithc81
So this is what I am working with. Looks like the previous owner tried to use jb weld or something to fit the ring onto the spacer. Does the ring normally stayed fixed on the ridge on its own? Thanks for the help this is all new to me.
Ciera2450
get a new line cutter. They aren't too expensive.
Which drive do you have? You can look up schematics online...
don s. has a sticky I think with some of the schematics and manuals......Look up the part number and order a new one.
"adults only" thread i think
keithc81
Its a 280 like yours, just not so nice or as white. Thanks I will look it up.
Ciera2450
In that case.... part number 839423
keithc81
I pulled the spacer out now and the prop still only pushes on as far as it does in the picture. Could the prop shaft be longer on mine?
Ciera2450
the spacer and line cutter should be "inside" the housing
What's behind the line cutter?
Are your splines and shaft free of burrs? the slightest burr will stop things from sliding on properly.
I had a hell of a time removing the line cutter due to a tiny little burr...I cleaned up the entire shaft before reinstalling and things slid on nicely.
Also, I think there are different types of props....but that line cutter and spacer should slide in farther.
Ciera2450
Not the best pic...but this is how mine looks
Ciera2450
It appears so. Should be threaded holes behind your line cutter that the zinc bolts to.
Just to check...there should also be a zinc on your transom plate..at the bottom.
keithc81
New zinc ring and line cutter ordered. I was going crazy trying to figure out why it looked so off and it was so simple. Thanks!
vince59
a stupid idiot from the workshop lost one of the fishing line deflectors of my sterndrive. I can not get the schematic to identify the part number of my AQ 290A-DP lower gear drive unit...can anybody help?
Don S
You need to start a new thread with your questions, not just hijack an old thread that even has a different drive.
