I have a Lowrance X67C fishfinder which has never worked 100% of the time. I suspect transducer issues as everything will work just fine for stretches and then it stops reporting the depth numerically and blinks the last reading. If you adjust the sensitivity all the way up and manually keep the depth range in line you can still see the bottom but in varying degrees of clarity. It is affected by speed, change of direction and depth (the deeper the water the less likely it is to work properly. I actually moved it to a diifferent boat and thought the mounting might be the issue or electronic interference on the old install but nothing changed. Any suggestions or insight would be appreciated. Thanks in advance.
