Having mounted many transducers (and mangling more than one install) I'll offer these tidbits:
I recommend running the boat in the water before the install to observe the transom in flight. Identify the area of least turbulence coming from under the boat.
Mount the transducer as low on the transom as possible while still keeping it level to the ground. You can always change the tilt of the transducer with the set screw, but if it's not level to the ground (side-to-side) you'll have to move/redrill mounting holes.
Mount the transducer as far away from the prop(s) as possible
I personally recommend a poly transducer mounting plate. Cabala's sells them, but I actually bought a 3/4" poly cutting board at a local restaurant supply company that works very well. This allows you to easily move the transducer if necessary, and also mount more than one transducer and associated cable clamps without riddling your transom with holes.
Use a good "below waterline" sealant. 3M does make great products but if you use 5200, make damned sure you have it right because a redo will be difficult if not impossible once it cures.
Hope this helps
