fishelite 480 sonar/gps battery drain
03ironhead
unit draining battery when unit is off.Unit works properly when it is on.
I can turn unit off and disconnect positive wire from battery wait a minute and when i go to hook wire to battery it will draw an arc.it will only arc that one time until i turn unit on and off again.
rndn
Re: fishelite 480 sonar/gps battery drain
Are you sure you don't have a wire shorting out somewhere? If not it sounds like you may need a new unit.
