fish finder fuses & wiring question
grady101
I have a 2003 Bass Tracker PT175. Everything works fine. I added a second fish finder to the bow. Trackers come with pre-routed wiring for the additional fish finder. I hooked up everything and the fish finder doesn't work/doesn't power on. Everthing else works fine as before. Anyone have a wiring diagram, fuse diagram for this boat? Any ideas on why the additional fish finder is not working?
Re: fish finder fuses & wiring question
If it doesn't turn on it is 1) not getting power or 2) it's defective. The locator needs a source of +12 volts and ground. Check your connections and use a meter or test light to check for 12 volts.
