Larry E
- Jan 1, 2012
- 161
Thought I might share that I was not about to pay the labor costs on reupholstering my side panels and motor box. So I purchased the material at a local yardage shop and dove in. Not all that bad if you take your time with it. Had to make new side panels (1/2 inch plywood) and then covered them with 1/4 inch foam and then the vinyl with edge beading. Motor box was also rotted out so used what I had for a pattern and then repeated the foam installation and then vinyl. Added the cup holder holes before I put on the vinyl. The motor box took some time figuring out the way to get material around the corners on the sides but it finally came out looking like this. NOT BRAGGING JUST SHARING.Larry E
