First time pulling the outdrive
fishingman220
i have an alpha one gen 2 drive and i have to pull it due to needing to pull the motor. the way i understand it, all i need to do is pull the six nuts and it should all slide out. my questions are, one, does the drive shaft come out with it, and two, do i need to drain the drive before i pull it. also one last thing where do you unhook the shift linkage?? i have tried to download the manual, but i am using a mac book and i do not have a right click button and i dont know how to get it to work. any help would be great.
Bt Doctur
Re: First time pulling the outdrive
Shift into full fwd, remove the trim rams, disconnect the speedo hose, 6 mounting nuts , pull straight back.
shaft and drive come out as a unit.
BigBK
When u pull the drive the shift cable will stay atatched to the gimble. you wont have to disconnect it at the out drive
fishingman220
all i am seeing is the cover sheet, there is an area clickable, but is not doing anything.
Bt Doctur
click the box that says
sterndrives
fishingman220
it is showing it is clickable but when i click it , it doesnt do anything
orion25
Worked for me. Saved it!
Click on the box that says "Sterndrive Units Alpha One Generation II".
jstutz101
For as hard as most things are on I/O's to get to or remove it is amazing how easy the outdrive appears to come off. I haven't had a chance to try it myself but I have removed the lower unit to replace the impellar.
Would it be smart to buy a new rubber gasket and oring anytime the outdrive is removed?
Jeff
mxzer29
Hi, I don't mean to jump in or hijack this thread..but we are removing the outdrive on the brother in laws boat, did everything you said but the drive won't come out??? We are removing because it won't go in gear..engin stalls when try to shift..
any suggestions??
thanks
Pat:confused:
fishingman220
got the drive off, my drive and shift bellows look good, should i try to replace them or wait, kinda straped for money, if i do replace them do i need to pull the part off that he drive bolts to??
