First Time Pontoon Boat Buyers
trout45
My brother and I are currently looking into purchasing a pontoon boat--our first boat--for floating down the Connecticut River. Based on past experiences with our friend's boats all we're looking for is something that can seat 10-12 and just coast downstream and do just a little bit of fishing. We don't care about pulling tubers, wakebording, or speed. Our focus is primarily on used pontoon boats made within the last decade, under $10,000 (with trailer, ideally).
We figure annual fuel costs will be about $1,200 - $1,500, winterization, registration, small tune ups and annual/biannual water pump replacement will run an additional couple hundred bucks a year. In the winter it'll be covered and stored in a barn, and we're aware that transport and launching/picking it up aren't going to be the easiest things ever.
All that being said, are we too far off with our expectations? Looking around the New England area we've found several appealing pontoon boats in our price range, but are there any particular brands we should look at?
And are there any other hidden costs we should prepare for?
Thanks in advance.
5150abf
Re: First Time Pontoon Boat Buyers
Welcome to iboats.
To get 10-12 people comfortably on a boat you are going to want at least a 22', 25 would be better, they are rated for load and 12 people at 180 is 2160 which is pushing a 22s load limit.
Your expenses seem a little high to me but that is good, if it isn't that much you come out a little better, unless you run the engine ALOT you should only need to change the impeller every 2 years and you could easily get 3 out of it.
Sounds liek you did your home work, just watch the load limit before you buy.
EGlideRider
Like 5150 said, a 22 is pushing your limits. While it may haul 12 normal size people, throw in a couple of big guys, fishing gear and coolers and you could easily be overloaded. 24+ foot will serve you much better.
Your estimates are close but you can count on yearly unscheduled maintenance costs on an older boat.
lncoop
24' barges are hard to beat and you should be able to find what you're looking for in your price range. It may take a little while to find one that size with a trailer though. Around here most of the 24 footers are bought new and delivered to a slip, so once they hit the secondary market they're sold without trailers. You always have the option of buying a trailer separately if you fall in love with a barge without one, but if you end up doing that don't let anyone talk you into a single axle. Sounds like a 24' barge with an 85-90 horse would be about right. I know you're not interested in pulling toys, but you might need a little more juice for the river currents from time to time. The nice thing about barges is the decreased potential for hidden issues. If the motor's strong (check compression please), the toons are relatively straight (a few dents are okay), and the deck is solid, there's not too much else to worry about, at least nothing major. Be sure and look inside the seats. Sometime around the late nineties most of the manufacturers switched from plywood seat bases to rotocast, which is far superior. If you're maxing out around ten years old that shouldn't be an issue, but take a look any way. Finally, if you have any experience towing any kind of trailer I think you'll find transport to be easier than you anticipated. Just be sure to maintain your trailer religiously. Storing the rig inside during the off season will make your life much easier. Good luck with your quest. Party barges and rivers are a great combination. I'm thinking about spending a weekend this summer floating mine down the Arkansas. Let us know how it turns out.
trout45
Thanks for the info. There are a few 24 footers on my list, some with double axle trailers, some without a trailer. From what I've seen double axle trailers for a 22' - 24' pontoon are around $2,000. With those trailers should I be looking for trailers that are entirely galvanized, or will just the wheels being galvanized do?
EGlideRider
galvanized or aluminum frames only.... No steel...
