first time owner
johndough
Hi, glad to find this site. bought a 1961 15" starcraft with a 1962 evinrude 40 hp Lark motor model 35530 or 35531. I had the boat out twice, ran like a top!, third time out, it starts great but no thrust to speak of at all. can get like 5 knots if lucky. I took off the prop nose cone , checked the shear pin, that is fine, looks like the shifting lever is making a full contact , forward and reverse. An older gentleman said maybe it was clogged with weeds??? the engine will rev up accordingly with the gas applied , however it is not translating to forward momentum. (note , when trying to apply more gas , it did seem as if it smoking more than usual.... also there is no spray coming out of the exhaust port bout halfway up the back side. Also, the owners manual lists a clutch slipping in the propeller as a possible cause of motor runs, but boat makes little progress.... Is there something else I can check? It is very odd, cuz one minute it was running great, I stopped in the middle of the lake, put it in reverse for just like 5 seconds to clar any weeds from the prop, and then when I engaged it again in forward, these symptoms started. Any one that may have an idea to offer , I would appreciate it greatly if you could drop me an e-mail to johndough@adelphia.net.<br /><br />too bad, my nephew and his daughter were very disappointed, she is only 3 and was really bummed out, but not more than me!<br /><br />Thank you anyone for your help in advance!!! Brian :eek:
johndough
Re: first time owner
boat revs but moves very little, shear pin ok. clutch problem? where is the clutch <br /><br /> motor is a 1962 , 40 hp Evinrude Lark model 35530 or 35531 (#'s on the owners manual, price 20 cents.) email is johndough@adelphia.net
Joe Reeves
John... What you are referring to is more of a shock absorber than a clutch. The prop consists of three items, the prop, vaulcanized rubber, and a bronze hub. The vaulcanized rubber attaches the hub to the prop.<br /><br />When the vaulcanized rubber fails, that allows the hub (and prop shaft) to turn within the propeller. The cure is to replace the propeller or have the propeller rehubbed.<br /><br />Best to do both so that you'll have a spare.
Hooty
There's a rubber insert between the prop and the prop shaft. This is the clutch the manual refers too. If it's slipping, it's called a "spun hub". There's a couple of ways to check it. If you have another prop, swap them out. If not, take the prop to a prop shop and let them check it. If the hub needs replacing, it's not all that expensive.<br /><br />c/6<br /><br />Hooty
Solittle
Have you replaced the water pump & thermostat? If not --------------
johndough
thank you hooty and joe, that makes sense to me. and if that spun hub prolem occurs, that would make forward progress little or none, correct? also, what kind of price would I look at to replace the whole prop, would that be a better way to go?
johndough
so little , I only bought the boat on monday, first time owner, am going to have a guy check that out for me hopefully tommorrow, why is it so long to the weekend. need to fish and boat. already know I need a much larger vessel, thought I would start small and get some experience. thanks, Brian
