First time outboard buyer-- HELP!
drake917
So I've been looking for late 70s, early 80s, Johnson/Evinrude outboard motors, about 10-15hp for my 14ft jon boat. I came across one through a friend the other day, Model number E10RCSE. I did some research, I believe this is a 1980 Evinrude 9.9 (10hp), Tiller handle, standard 15" shaft length. With that being said, he said that it runs but will die so you have to keep pumping the bubble in the fuel line from the tank, so i'm assuming it needs a new fuel pump. Is this true? What else should I look for when purchasing this motor? As a young-first time buyer, what should I look for/beware of? He said it's originally from Illinois, and that it has not ran in 5+ years. My mechanical experience is limited as of now, but very willing to learn, just want to make a sound purchase.
Also, based on these facts above, what is the max you'd pay for this motor? The exterior looks nearly mint condition, so it appears as if it was taken care of very well
HighTrim
Re: First time outboard buyer-- HELP!
Sure does sound like a fuel pump.
After sitting, it will also need a carb clean, impeller, gear oil etc...., just to be aware. Depends on your mechanical ability.
drake917
How much do you think the outboard is worth? Also whats a new fuel pump run for just parts? $150? I have a family member who is very inclined with motors and can help me, but he's out of town for 2 weeks and wouldn't be able to look at it with me before I purchase it
jakedaawg
I would pressure test the lower if it has been sitting for five plus years. If it holds pressure do not pay more than two hundred, if it does not hold pressure tell him you will take it off his hands for free. Then you can learn how to seal one. Fuel pump is no problem. Just my humble opinion.
HighTrim
Depends on alot, condition, mechanical condition, etc...
I would check compression first and foremost, the rest can be easily fixed. If compression is ok, and you can get it for a good price, grab it. By the way, it is a 1980.
In running condition, they really hold their value in my local area. Being that the one mentioned is a non runner really, offer a couple hundred bucks and see what happens.
