first time boat owner that is mechanically inclined
cda184
I bought a 91 crestliner with a johnson 150hp vro. Put it in the lake and started cruising and got it to 32 mph wide open for about 3 to four mins. And then all of sudden it acted like something unclogged in the carbs because the rpms went up and it jumped up to about 43 mph for about 30 seconds and then the motor started making a rattling sound and then it stalled and would turn over but not start. When I got it back on the trailer I tried to start it again and it started for about 5 secs and then died. Any ideals what it could be. I'm going to do a compression Ck this afternoon to rule out internal engine damage.
Boat Doctor1
chech =compression, spark & be sure to look on thye spark plug ends for alunimum!! That being done & all ok?? Id go to carbs!! its likely spark dying / coming back on & or -carbs!!
Honorary Supreme Mariner
Did you check whether you need to mix the gas and oil ???----Is the VRO unit working as it should ??---Did you confirm that the VRO is still in service ???-----Start with the compression test as the rattle is a huge concern.
aspeck
The rattle is the concern ... I didn't like the older VRO's because I didn't trust them ... to many disconnected or not working and without oil, engine go boom! May or may not be an issue, but check it. I always mix a little oil in the gas just in case the VRO craps out. Would rather be over mixed than no oil ... start with compression and plugs and work backwards from there ... compression, spark, fuel, air ...
Bosunsmate
Look on the external of the engine for any loose mechanical connections.
Id then check for big end bearing wear at tdc when you have the sparkplugs out too
emdsapmgr
You may have two separate issues. During the first part of your test run, it may not have been firing on all 6 cylinders. After that 4 minutes, the 6th plug may have started firing. Possible an ignition problem. The rattling may be a separate issue. Did the engine suffer an overheat? Do you know if the overheat warning horn functions? If the engine overheated, the pistons swell inside the cyl liners and it's hard to crank/start till it cools down.
cda184
Alright guys. I checked the compression on my 150 johnson vro and all but one of the cylinders but one got 90 psi and one didn't get nothing. Now my question is its a 1990 motor. Would it be worth rebuilding which I can do myself or buy a newer used motor
Pull the cylinder head for inspection.----Another used motor may also have issues.
emdsapmgr
The best case scenario would be if the head gasket on that crossflow is bad. A cheap fix. If you pull the head and find anything else inside, it will be expen$ive. How mechanically inclined are you?
