First time boat. Need some help
Status
Not open for further replies.
Chelseafc
Hi all thanks for all the useful info each of you provide.
As title suggests, I bought my first bought for my young family to take my kids fishing.
I picked up a 1987 aquasport striper that I was told was in good shape. I had a friend of mine who owns boats come check it out for me. He have the green light. We test rode it , everything was great.
First time I took the boat out the week after, started like a charm. About one minute into the ride , the motor died. Long story short, I thought it was a fuel problem. I . I was told that the boat was losing prime because it was dying after idle for maybe 10-20 minutes. Changed primer bulb and it seemed to be better. I also changed battery due to advice that battery was not good.
Next time out, it had a hard time starting. Had to crank several times, kept cutting out suddenly at idle but not the same as the prime deal. It died very suddenly. eventually it ran and I took it out. However, I noticed that the battery was low from my gps and radio
I stopped to fish for a whole , tried to start an hour later and no juice. I could hear the starter turn but no juice. I had a battery pack so I jumped it. Took it on a ride for maybe 20 minutes hoping it would charge. Shut down and tried again, no juice and had to bump again. I think I bumped it 3 times to get moving again.
When I got off and pulled the boat, I noticed that my hummingbird transducer had some melted spots. I am not 100% sure that it was not melted before I bough it but I do not believe it was.
I am thinking I have a short circuit or something electrical that was causing the problem to start with? The melted transducer and the battery that drains quickly ( not sure if it's considered quick for a new battery to have no juice at all after 5-6 starts)
Any ideas on what the problem could be ? What can I do to fix it ? Help is greatly appreciated
tpenfield
:welcome:
to iBoats. . .
It sounds like you may have 2 problems, but best to fix one at a time. the dead battery, melted hummning bird sender, etc.
Disconnect the humming bird and see if all is good. If not, then I would check for anything else that may be drawing lots of current and sucking the life out of the battery. If not I would suspect the alternator on the engine. . . .maybe the battery is not getting charged.
Once you can maintain a good battery, take a look at the fuel system. Maybe run a high concentration of fuel system cleaner through it. 2-cycle outboard engine ??? Clean the spark plugs . . .
I'm always skeptical of boats that 'just need a new battery' . . . why is it dead?
Post some updates as you go.
mr 88
A lot more info as noted is needed. What engine do you have ? Fuel filters been changed ? How long has it sat ? Carb rebuilt or loaded with rubber that has broken down in the fuel line from sitting for years ? Once you have the engine manufacturer post the question in the dedicated engine forum down a few listing from the general forum where you have this posted.
Status
