First Start of Spring... DIDN'T START!!!!!!
Re: First Start of Spring... DIDN'T START!!!!!!
It could very well be the carb. This thing hasn't been started in two years, until today.
saltybutwet
So, we are talking about the lines, the fuel pump, the carb? The whole works?
yep, you may have an anti suction valve on the fuel tank that may have went bad, if you have one....other fuel related items need to be checked
Ok, next possibly stupid question from me. How do you get to the fuel tank to check that?
saltybutwet
you should go download that manual...it has troubleshooting sections in it...I have used it and learned a lot from it
Ayuh,.... It's ALL Suspect,... You've gotta figure out What's Bad....
Hook a remote tank, fulla Fresh gas to the fuel pump, 'n Try it,....
If it starts, 'n runs, you've eliminated the fuel system past the fuel pump, 'n the problem is somewhere from the tank on,...
The gas in the tank, 'n the anti-siphon valve would be suspects #1, 'n #2,...
If it Don't start, yer down to the fuel pump, Or the carb,...
airdvr1227
2 year old gas can't be helping the situation any.
thompson80
Most newer boats have a cover deckplate over the fuel tank near midships, on centerline and between the seats, that unscrews (mine is a 1980, and has one). Look for that. But first, consider this: I have the same engine (140 Mercruiser, same as the 3.0, just not fuel-injected as the new ones are, and built in Detroit - the new ones are Hecho en Mexico, but essentially the same venerable block). Great little engines, but cold-blooded as heck - at least mine is. After cranking forever and finally firing, mine then still takes awhile to feel like running on its own (yes, with fresh gas). Even if it's been sitting a day or so after running, it takes a ton of cranking just to start. So before you start getting crazy tearing into things, Bondo or whoever mentioned dripping some gas into the carb to prime it first, made a good suggestion. Just be sure to put your flame arrestor back on before cranking. Burned eyebrows - or worse - and boat fires are NOT fun. But FIRST, get rid of that old gas, and fillup with fresh. If you can get it to start and keep running, warm it up to full operating temp. (at least 140 degrees) and then shut it off. It should then restart without much cranking. Mine does. If it does not easily restart, THEN you get to run down the trouble-shooting list. Done a tune-up in the last two years? No? It's time for that, then, in addition to the fresh gas. You're going to pay a shop $110 or more per hour, PLUS parts, to do this for you, and most of it is easy and requires just basic tools that should be in the boat all the time, so do everything you can on your own that you are capable of first, before going to the pros. Again, I'd pump that old gas out first. Use it in your lawnmower or put a few gallons in your least favorite car once a fillup. You ALWAYS want FRESH gas in a boat. It's one thing to have a lawnmower issue, another thing to have boat troubles when the fish are biting.
MikDee
Banned
I hope by now you are running it in a barrel of water, or on a garden hose with ear muffs! Or, you'll fry your water pump impellor
UPDATE!!!!! I narrowed my problem down to the fuel pump. It wasn't pumping hardly any fuel. I took the pump apart and cleaned it with carburetor cleaner, then put it back on the motor. The boat now runs like a charm. Thanks for all of the help guys!!!!!!!!!
And yes, I do run it with a pair of muffs on a water hose.
