imstillatwork
- Jan 22, 2005
- 169
And I found a slight problem.<br /><br />My brother and I launched and took a few test runs in the mouth of the Chetco River in southern Oregon (in case anyone saw.....). The motor that I hade been working on all winter ran great! The boat drove really well, for being a old fixer upper that had sat for at least 2 years. So we headed out to the first bouy (1/2 mile or so), headed up the coast another 1/2 mile or so. We were out for about 30 mintes and headed back in. <br /><br />Right when we reached the harbor entrance, the boat died. It slowed down, then completely died. The battery was dead. Here's what I've found out since I got back:<br /><br />With battery recharged and motor at idle on muffs<br />14.3-14.6v at the battery.<br /><br />Battery only: about 12.2-12.5v<br /><br />Heres what is odd:<br />When I hook the battery up I get a small spark when the last lead is connected. If I tap the lead to the battery I can here a movement on the motor. Further testing showed that the flywheel would twitch as I taped the lead to the battery post.<br /><br />Key is off the whole time. <br /><br />What should I check for? I thought I checked the output of the alternator before the regulator, but can't remember a voltage. Should be around 14-16v at idle, right? regulated to 14.x for charging?<br /><br />What would cause the alternator to take a current and try to spin the crank with the key off? <br /><br />AND: if the output voltage is 14.x to tha battery, it should stay charged....bad battery? a bad battery explains why id drained, but not why a charged battery sparks when you hook it up. I think I have two problems at once, but the motor drawing power while off is the most important I think. <br /><br />Good thing we were at the port whenit died and not out a mile away. had fun anyways! please help!
