fires but wont run?
myrdon
105 hp chrysler wont start but has spark and will fire when choke but wont run? can you help me ?:confused:
drewpster
Re: fires but wont run?
Fuel system problem. Check and make sure that the gas is getting to the engine from the tank to the carbs. If the gas flows freely from the tank to the carb inlets, the carbs probably need to be cleaned out.
jerryjerry05
Did it run recently?When did it run last? Did you do a compression test? Check fuel lines.Check squeezie. Tell us what the comp is.Jerry
