Finding parts for an 1987 25HP Merc.
James R
This motor has the number OB236360 which appears to be a 1987 model. Searching the usual links such as boats.net and mercruiser parts I have not found this motor. The motors shown do not show the primer actuating mechanism and the start advance link that I am looking for.
The carb is similar to those shown with the primer pump so the carb kit should not be a problem but I need the link. The plastic coupling has britalized and broken off.
Help is very much needed.
Thanks in advance,
Fun Times
Re: Finding parts for an 1987 25HP Merc.
This is your engine.
http://www.mercruiserparts.com/selectDocs.asp?doc_nbr=13286\
The motors shown do not show the primer actuating mechanism and the start advance link that I am looking for.The carb is similar to those shown with the primer pump so the carb kit should not be a problem but I need the link. The plastic coupling has britalized and broken off.
Thanks in advance,
Is this what your looking for?
http://www.mercruiserparts.com/Show...4&bnbr=230&bdesc=HARNESS+AND+START+COMPONENTS
James R
Amazing! Now why could I not find that?
You are a life saver Boat Tech.
Thank you so much.
