Find old parts
Kadaddy
I have a 1975 Eldocraft bass boat. On my last trip to the lake this happened.
Here is the other side to show what the fitting looks like.
Is there any chance I can find a replacement part or do I need to manufacture something?
you can check ebay, etc.
however you will most likely need to fire up the welder and fabricate something.
Wildey
I would carefully check the integrity of the transom.
Looks like there may have been substantial movement at that junction.
Kadaddy
Thanks for the replies. I figured I would be making something.
Transom is solid. I’m thinking that rubrail insert has shrunk up so much it pulled loose.
Kadaddy
Thanks for the Taco Marine suggestion. I had looked there earlier. I had the original caps in mind and didn’t see anything at that time. Revisiting things I found something that I think will work.
