Roadblock007
Thread starter- Joined
- May 24, 2017
- 142
I just bought a 1991 Bayliner Capri 1850. The boat passed all of my tests and is very solid. Motor is 3.0L Mercruiser with Alpha One outdrive. Tach doesn't work and neither does speedo. I found the air line disconnected at the fitting behind the prop, but want to blow out the line before I reconnect it since who knows how long it's been off for. As for the tach. I see a gray wire coming from the harness from the dash and I see 2 wires coming from the distributor. Neither are connected to each other. I will post pics later for advice on that. Thanks for all the advice, it really helped me. I went through numerous garbage boats before finding this one and I never would have found all the issues I did without you guys! I would have bought something that was trash.
