Watermann
- Jan 12, 2013
- 13,837
If I were to guess, the button puts it into gear. If you don't push the button, you can throttle up/down while-in neutral (or vice-versa).
If the button put it or out of gear then it would not need a warm up lever, it would be like a control that pulls out the shift lever to make it only advance throttle like my Chief has..
It may be worth mentioning that you're not supposed to put it in gear while on muffs. Correct me if I'm wrong, guys...just something I remember hearing/reading and have since observed.
Yeah you can put the motor in gear on the muffs at an idle but done revv the sucker up and make sure no kids or dogs are around. Oh and be sure the muffs go on from the front!
