Filling in holes in aluminum boat
10point
I took an old transducer off the bottom of my boat. What's the best way to fill in the two small screw holes?
v8George
Re: Filling in holes in aluminum boat
The best way? TIG weld it.
Easiest way? Stainless nut and bolt with a silicone washer on each side. You could also glass it over.
Bigboyitm
You could use sealed pop rivets to seal it also. I would put some silicone over the hole and then pop rivet it.
jbcurt00
You can do a search from the iBoats restoration forum page & find quite a few threads &/or posts about filling holes in AL boats.
This is one of those threads
