Maine winter has arrived and I have dove into my long awaited boat project. I am converting an inboard shallow draft fishing boat into an outboard Striper Seeker. It is a unique boat, custom made in Nantucket called a Grey Lady 25. Anyway, the transom seems to be plenty adequate for the conversion, however, there is a prop pocket / tunnel left from the inboard to contend with. I thought about leaving the tunnel and mounting the new 250 outboard on a Porta hydraulic bracket with a 27" or 30" setback. I figure I'd try it out and see if it created any downside like cavitation, etc. Best case it may provide a little lift in the rear.
I am re-thinking and opting for an Armstrong bracket for the floatation and swim platform aspect. Problem is, I have to attack the bottom as the Armstrong bracket follows the contour of the hull and sits only a couple inches away from the bottom at centerline.
The pocket is about 24" wide, 48" long on a tapper and 12" deep at the transom. Obviously, simply filling the pocket would be cosmetic as the structural element is already there. A friend in the business suggested filling the pocket with foam (I forget the name of the stuff), laying up a few layers of glass, and fairing. I am sure it would work, however, I hate doing things half ***. What about cutting the pocket out and re-doing properly? I would then have great useable space under the deck where the top on the pocket resides and if I ever sell the boat ("a boater's best day") there wouldn't be any question about the filled in pocket void.
It just so happens that I have access to the original mold and could have the guys lay me up a section of the bottom and transom. The problem is...then what? I don't want to get over my head here. Plus, I am on a limited budget; thus I am seeking help on the forum. Is this a viable option? or should I fix it the old fashion way (what ever that is?). How do I support it? Now it becomes a structural issue right? (by the way, the hull is solid glass with no core) Am I overthinking this or is it pretty straight forward? I could use some suggestions (or a step by step if so inclined).
Thanks in advance
Thanks in advance
