ficht fuel line replacement
jedimaster
juat wondering qhat fuel line i ahould use to replace the fuel lines between the injection unit and the fuel manifold? Dowa anyone know the psi between?
daselbee
It is no more than 35 psi.
But you have to replace the whole distribution line/manifold assy.
They made the part like they did to avoid fires caused by leaking fuel lines.
The part is only available new (maybe) if you call a dealer.
You can get them used all over the place, cause these motors blow up.
jedimaster
i konda thought so do you know if the lines that attatch to the fitting on the DI unit get heat shrunk on or do you have to replace those fittings as well?
daselbee
The fuel distribution manifold as a complete assembly comes with the fittings assembled.
DI unit? You mean high pressure fuel pump? Vapor separator assembly....
jedimaster
I meam the connection to the fuel injector assembly. the hoses look like they are shrink wrapped type connection
