Ficht 225, Yes/No?
jacktar
Considering purchase of a 2000 boat with twin 225 Evinrude FICHT. Considering all the problems I've read about, should I walk away, or take a risk. The engines have 120 hours on them and the port gearcase has already been replaced. No current warranty. Purchase price is fair, but if I wanted to repower, no one in SC will give a fair trade-in price. Am open to all comments. Thanks, Frank :confused:
willxuout2
Re: Ficht 225, Yes/No?
You've already stated the obvious. If you can get the whole rig for what the boat, trailer, and gear is worth then go for it. Just remember that it will cost you about $1500 to re-rig the boat for different motors plus the cost of twins :eek: <br /><br />I'd walk away. Just my opinion.
Fly Rod
If you purchase new fichts then you more then likely won't have to re-rig. When I upgraded from a 2000 225hp ficht to a 2003 225hp didn't have to do any re-rigging.<br />After having a new power head installed on the 2000 I imediately traded it. Up here the 2003 listed for $14,000.00 and they gave me $7,000.00 for the trade.<br />The 2000s were a bad year. I know of a 1/2 dozen in my area alone that all trouble.<br />If you like the boat try to make a deal for the boat only, with no engines.<br />A very good friend of mine, 82 years young has always said that when buying an outboard always buy a new one and use the 1st half and sell the 2nd half. He is so, so, right. After owning several new ones I went and bought that clunker.<br />How big is the boat that your buying ????
BRIAN03
You need to have a friend that fixes them. They will wear you out unless you have a large trust fund. The only people who run the big Fichts here do it out of principal. See I run them. They have them worked on everytime out.
jacktar
Thanks for your coments. You are confirming what my gut is telling me. The boat is 29 feet and is a very sturdy and an extremely well equipped center console. I've only had two other outboards in all my years of boating and one was junk. When I ran charters on the Chesapeake, all my boats were inboards. However to get the most out of all the water around Charleston, you need to be able to run the rivers and the lakes so shallow draft is mandatory. I'm giving it thought. Frank
Cricket Too
jack....I have a 2000 150hp Ficht with about 300 hrs. on it and have never had a single problem, have never done anything besides preventative maintenance, and it has given me nothing but pleasure. The main problems with the Ficht's were the early years 97-99 and were mostly in the 150 and 175 hp ranges. The bigger blocks were not as troublesome and anyway I believe that by 2000 they had most of the problems with the 150's and 175's worked out. I would probably go for it. The gearcase problem has nothing to do with it being a Ficht, that could have happened to any motor. I'm not saying that there are not guys out there that haven't blown the 200's and 225's, as Flyrod did, but there are also people who have put 100's and 100'sof hrs. on them. Ther are also guys who have blown 50 - 100 hr. carbed engines due to one problem or another. I had a friend blow a 99 150hp Johnson after 50 hrs. due to faulty carbs, the dealer replaced the powerehead and carbs and it has been fine ever since. The Ficht's get a bad rap due to early problems and I would probably be pretty cautious if I were buying one used, but I wouldn't rule it out, and 150 hrs. is very low for a 2000 and you should ask the guy what kind of pm was done to this motor and if he ever had any updates done to it or if it was ever in for any problems specific to the Ficht system. If you could get them looked at by a qualified Ficht tech and he could go through and check them out for you, you will have a much better basis for your decision. I'd probably give them a shot. Good luck.
