Fiberglassing and hardner mixing?
Catchem
Hey guys,Never really done this kind of work before so I'm looking for some help from all you experts out there.Going to fiberglass my stringers and floor in here soon but not sure what mixture ratio I should be using.I have a 5 gallon pail of resin and a gallon of hardner.Is that enough?Have a roll of heavy fiberglass mat also for the floor and stringers that I am assuming has to be totaly saturated when putting it on.Question is will it stay up on the vertical pieces?Also when I saturate this mat do i just brush this on and then roll or do I have to dip it in the pail.Appreciate any help from you experts out there.Thanks to all that respond.
Harker
Re: Fiberglassing and hardner mixing?
Follow the mixing directions on the can...is it epoxy? The cloth has to be saturated..you can make a small box from plywood that is a bit bigger than your largest piece of cloth, then pour som resin in and lay your cloth in it and pour some on top..work it with a roller or squeegee till it is wetted out the put it where you want it and roll or squeegee the excess resin out of it in place so the resin doesn't "float" the glass off the area you are adhering to.
petrolhead
You don't mention what kind of resin it is, although from the quantity you have it sounds like epoxy, and probably 5:1 ratio?<br />If it's polyester resin the mix will be more like 2-3% hardener.<br /><br />For vertical surfaces I would cover the surface with resin using either a brush or roller, press the dry cloth onto the surface and it should stick, then add more resin with a gloss paint roller and use a paddle blade roller to work it well into the fibres and work out any air bubbles.<br />White patches mean the cloth isn't fully saturated, when it goes almost clear that's an indication that you've used enough resin and have got the air out.<br />If you pre-wet the cloth you'll have to use fairly small pieces, large pieces will flop around all over the place and you'll get into all sorts of trouble!<br />Have a look at the WEST System website http://www.westsystem.com/ for some quite comprehensive and easy to understand instructions.
ThomWV
And More:<br /><br />Some things bothered me about your post because they hinted that you might be getting ready to make a mess, but that maybe it doesn't have to be that way.<br /><br />First let me tell you a couple of things about resins that you really need to understand. Let's start with one of the real basic differences betweem epoxy and polyester resins. With epoxy you control how long it takes for the resin/hardner mix to set up by using different hardners. Some are very fast and some are very slow. With most epoxy's you can mix hardners to adjust the set time, which is to say that you can mix half fast hardner with half slow to get a medium set time and you can vary the proportions to suit your needs. In general slower is actually usually better. In any event it is very important that the proper ratio of hardner and resin be mixed together. Too much or too little hardner and you end up with a mess that generally won't set up at all. <br /><br />Polyester is much different in that reguard. With Polyester you control the set time by how much hardner you use. More hardner means a faster set.<br /><br />Temperature is a governing factor in set time too. Hotter equals faster. No suprise there. Well, sometimes there is a suprise. Resin/hardner mix generates heat as it sets up and that heat will speed up the set. The thicker the application the greater heat is retained and the faster the set. Here is how it works in practice. If you were to take one of those generic plastic paint cans that Lowe's and Home Depot sells with their graduated sides (get a half a dozen of these things along with rags and hand cleaner before you even think about starting) and mix up a quarter inch of resin/hardner it might take a half hour to set up on a good warm day. Take that same can and fill it up half way with resin/hardner and I can guarantee you that in 10 minutes it will either be hard as a rock or on fire. The deeper the mix is in the pot the faster it will set up and the hotter it will get. In the worst case the top of the mix will actually begin to bubble and turn brown from the heat, in many cases it will smoke and rarely, but occasionally it will actually burst into flame. Both epoxy and polyester will do this. On the other hand if you were to mix up a batc of the stuff inside of the tray for dipping a roller and have it very shallow, say 1/8" deep or so, it might take it a day to set up. Thin applications of resin/hardner take forever to set up.<br /><br />I only said this stuff because you mentioned that 5-gallon pail. If you mix up your resin in it with the thought that you are going to have time to then use that stuff to glass your boat you are mistaken. You pour a gallon of resin in there along with its hardner and what is going to happen is that its going to become unusable in mere minutes, unless you happen to be in the artic.<br /><br />Next. Fiberglass is strongest when the least possible amount of resin is used but still fully saturates the actual glass. That is why application of the resin (when I say resin from now on I mean resin which has been mixed with the appropriate and proper amount of hardner) using either a paint brush or a short-napped roller works so well. It tends to limit the amount of resin you can carry to the piece of work and that is to your advantage. Dipping the glass in a vat of resin almost always results in a couple of things. The first is one of the worst messes you'll ever see. The second is cloth that stretches and becomes essentially unusalbe. The third is most important. It results in a mix that is far to rich in resin and lean in cloth and the result is a much weaker peice that would otherwise have been the case. Don't dip it.<br /><br />As for the application technique. Try this, staple the cloth to the stringer and then wet it out. If you don't like that one try smaller strips of glass and apply them overlapping. By the way, don't overlook the use of fiber glass tape, something around 4" wide works wonders. There is also bagging and its really the way to go if you have anything you can use as a vacuume pump and are somewhat innovative in your approach to things. I will say this, if you can rig up a bag system, which can often be done with simple plastic and duct tape, the quality of the job you turn out, both in appearance and strength, will be greatly improved.<br /><br />So those are some hints that I would give. I would absolutly love to see some from guys who do a lot more glassing than I do. I know there are some builders here, and of course they do a lot, and there are some real serious hobbiest here, and you know some of those guys are turning out some outstanding work (I know becasue I've seen the pictures here) and should be able to give you, and me too, some pointers.<br /><br />Thom
self taut
quick note: be sure you do not put more hardener into the resin than is called for.in many cases.and for certain in a poly resin too much hardener will cause (although interesting ) possiply a dangerous situation. the mixture can become very hot and begin to bubble also puting off smoke and fumes. within an extreamly short time period the mix will become hard as a rock. total time 10 to 15 min.had a buddy who did this recently.unintentionally of course but he figured the more haedner he put in the faster it would cure.always follow the directions as close as humanly possible.
Catchem
Wow,Lot more here than I ever suspected.Thanks for the quick responses fellas.Like I said earlier I am definately a novice in this area.Not sure if my"5 gallon "pail is epoxy or polyresin,will have to check that out.I think I will definately do it in small pieces and I will try mixing small quantities until I get the knack for it.Learned a hell of a lot from you guys already.MUCH APPRECIATED.Thanks,and keep it coming because I'm printing everything so I don't<br />miss anything.Always nice to know there is good people out there willing to share info.....Hope I can return the favor someday.
mike323
epoxyhelp.com<br />It is intended for S3 products, but the info is very useable.
petrolhead
I'd be very surprised if anywhere would sell you a gallon of polyester hardener, that would be enough for 50 gallons of resin!<br />For that reason alone you probably have epoxy, the resin and hardener are normally sold in the appropriate quantities.
ThomWV
I agree with petrolhead that it would certainly be unusual for you to have bought a gallon of hardner for polyester. At the same time I have to sitting here thinking about what if it were Epoxy. Do you have any idea how much more 5 gallons of epoxy would cost you than 5 gallons of Polyester, never mind the hardner. We're talking about something on the order of 4 or 5 times the money for the epoxy. That should be something easy enough to remember. I'd immagine you could pick up 5 gallons of polyester for maybe $75. Five gallons of epoxy is going to cost you right in the ballpark of $300. So that might be one way to tell which one you have there.<br /><br />Aside from the price, and the fact that its much stronger and bonds better than polyester, epoxy has a bad side that you should know about. As nasty as Polyester smells in comparison to epoxy its still easier on your health. Sooner or later if you work with epoxy long enough you are going to become very sensitve to it and that will be the last day you ever use it, one way or another. I have been told that the sensitivity really develops in response to the hardner, not the resin, but the point is moot. You still won't be able to use the stuff any more at peril of your life. Now the thing is that epoxy has a much less pungent smell and its no harder to clean off of yourself (use a cream hand cleanser, just like you wold for grease) than polyester, but it will get you sooner or later. For most casual users this will never happen, but sometimes it does, and eventually to all heavy users of epoxy. So wear rubber gloves and keep the stuff of your skin. Don't use it anywhere there isn't adequate ventelation and I'd suggest eye protection too. You don't have to go crazy, but be careful.<br /><br />Thom
E. E.
I'm not sure about epoxy but before pouring out a gallon from the 5 gallon bucket, mix the 5 gallons very well. Other wise the first batches will take forever toharden and the last batch will harden before you have to say what just happened. It happened to me and I wasted a gallon of hardened poly.
Catchem
Good info guys,Thanks.Just so you know,I have cartridge mask with proper cartridge filters and eye protection,tons of rubber gloves,disposable paper coveralls.I don't take anything for granted when working with chemicals.I also belive the resin I have is polyester.This is the same kind they use in lining inside oil tanks and chemical tanks.It was left over from a previous job and a friend of mine gave it to me for nothing.Can't argue with the price.Again thanks fellas and if you have any more keep sending.
petrolhead
Good to hear you're safety conscious, I see too many guys playing around with this stuff like it's totally harmless. I use both polyester and epoxy regularly in the course of my business, I couldn't afford to become sensitised to either and not be able to use it so I take whatever precautions I can, wearing a proper mask and gloves, and working outdoors with them whenever possible rather than indoors.<br />If I do have to work indoors I do it in the sprayroom with the extractor fan running.
Catchem
Petrolhead,I am outside in my driveway doing this work.But.... and there's always a but,since i am doing this outside does this stuff have a strong enough smell to bother my neighbors?
petrolhead
If it's epoxy the smell will be unnoticeable from a few feet away, if it's polyester the smell is strong and will carry quite a way, try to pick a day when the wind is blowing away from your neighbours!
Catchem
Thanks Petrol,will keep that in mind.
JasonJ
I used gloves respirator, the whole 9 yards when I rebuilt my boat using poly. Even still, all my neighbors knew when I was working on my boat, and they made sure to let me know they knew on occasion. Whats a person to do....
Catchem
JasonJ,Tell em you'll take em for a ride when your done.LOL.Hopfully my last question before I start this job...What is the best kind of brush to use on this job and what cleaner to use for the tools and me?
petrolhead
Rollers are much easier and quicker than brushes, especially on vertical surfaces. You can use a standard paint roller and tray, the roller should have a short nap cover so it doesn't soak up too much resin. Get several covers, you may want a foam gloss roller for the final coat.<br />You could probably do with a few cheap brushes for awkward corners where the roller won't go, but don't bother buying anything but the cheapest as you'll probably be throwing them away anyway!<br />You should also try to get a metal paddle roller which helps to impregnate the glasscloth with resin, you should be able to get this anywhere they sell GRP supplies. <br />For cleanup you can use acetone, but whatever you do DON'T use it to clean bare skin!<br />BTW, you have to clean all equipment before the resin gels, as soon as it starts to gel it's already too late!
PW2
Mostly good advice here.<br /><br />A few tidbits. Be very careful with this stuff, especially with the hardener (catalyst) It is a very strong oxidizer, and never use it without good eye protection.<br /><br />If it is indeed polyester, a gallon of the catalyst is way overkill. try a few small sample pieces first, and try a few different mixes, from say 1.5% mix to 2.5%. Measure carefully.<br /><br />If the resin has been sitting around a long time, mix it thoroughly first. There is stuff mixed in it at the factory (cobalt) that must be consistent in the mix. If your samples show an appreciable difference in hardness from one to another, use fresh resin and fresh catalyst.<br /><br />Acetone is the only thing that can be used as a thinner, but be very careful with this stuff, as it is extraordinarily flamable. <br /><br />The two keys to proper results are dryness of the stuff you are putting it on--If it's wood, it should be dried indoors for a month or so in a low humidity environment--even plywood will pick up 6-7% moisture at a lumber yard, and that is too much.<br /><br />The temperature that it is used in. Ideally it should be 70 deg F (about 23 deg C, I think). Try to pick a day that it does not very more than 5% or so from these temps.<br /><br />Good luck!
quantumleap
Master Chief Petty Officer
A plastic bondo type scraper works well remove excess resin and bubbles after spreading resin with brush or roller. Don't use too much pressure and don't try to work with it after it starts to set or you'll just introduce more bubbles. The main thing when starting your project is to have every thing cut and set up ready to go when you mix up your resin in small batches. Have it all planned out in advance. If something doesn't turn out right you can always grind it out and re-glass. Good luck.
