Re: Fiberglass Worry
If its still tacky a day later you didn't over catalyze it...but is it soft to the point of being rubbery or just tacky on the surface? If just tacky its probably laminating resin and is meant to stay tacky so no sanding is needed for glassing later. If soft and rubbery after a day or two the glass job is highly compromised and adding heat really won't help. Polyester has to initially kick (hard but still has to reach the max strength) within a certain time to get the max strength and I've never seen mfg charts that showed initial kick time to be more than a few hrs. Not that it can't be longer but I've personally never seen it. When to that point there is nothing that will restore the strength. Glassing over can give strength but it will still leave a soft under layer and adhesion of the soft layer might be a problem. Only in the long term (months to yrs) will soft polyester jobs like that get "dry".
Perhaps the local resident resin expert here can provide a poly kick time graph from the company he works for which will give you proof on how it works. The graphs I've used show temp, humidity, catalyst %, initial kick time, final cure time and hardness range...from minutes to weeks. You add or subtract values based on local weather conditions.
bp
