toberlindacher
- Jul 3, 2009
- 21
So, I just did a fiberglass repair on the deck of my boat. I coated the stripped and repaired deck board with a marine grade wood sealant and then put fiberglass over the top to match the rest of the deck fiberglass.
It felt like it cured just fine but two days later I got a couple of drops of water on the new fiberglass and the resin became a bit tacky. I am concerned because I am going to lay new carpet down on the deck and want to make sure everything is fine underneath when it gets wet in the boat. My questions are:
1. Shouldn't the fiberglass resist the water?
2. Do I need to put anything down on the new fiberglass to make it waterproof before gluing the carpet down? Will the fiberglass keep water from invading the wood deck?
3. Do I need to put down a coating of poly-vinyl alcohol to help it fully cure?
Any help would be great. As you can tell, I'm kinda new to the fiberglass-over-wood/deck thing.
