Fiberglass Epoxy Resin For Carpet Adhesive?
Voges123
Could i use epoxy resin for carpet glue,i no it would be expensive but im looking for an adhesive that will keep my carpet down.Any help???Thanks
ShadowB
Re: Fiberglass Epoxy Resin For Carpet Adhesive?
I've used Synergistecs 240 on my Tracker. Works great and has lasted a long time. I bought at Bass Pro. Think a pail was $20.
Voges123
ok soudns good thanks i get my carpet monday an i need someplace thats local so i wont have to wait on the adhesive.
James R
I have done several boats and always used ADAP outdoor carpet adhesive. Currently about $16 a gallon. Very manageable and the carpet will not lift no matter what. This is not wimpy kids stuff. Cleans up with spirits very easily.
Voges123
james r were can i find this stuff?
Try the Home Despot or Lowe's/ They have outdoor carpet adhesive in oil and latex. I chose the oil based
Bob_VT
To answer the question....NO do not use fiberglass resin as an adhesive for carpet.
I personally have used 6700 indoor outdoor carpet adhesive that I purchased at my local HD but, just be sure to pick up a few disposable notched trowels and spread it out per the directions.
James R
My apologies Vogues. The product is APAC 630 Outsider 2, made by All Purpose Adhesive Company Dalton Georgia 1-800-747-2722. Google APAC Adhesive.
You apparently NEVER plan to remove the carpet huh????
James R
Hi Silvertip. The original post asked for something good. Low odor mineral spirits will soften it but it will crack off with a scraper.
Moody Blue
Second the 6700 outdoor carpet adhesive from HD. Have used it on two boats now with great success. Used properly, that carpet will be there for a LONG time. Once the glue sets, it is virtually permanent. If you happen to get some on the carpet or your clothes, get it off right away with some warm water and soap or it will be there forever.
I use the same glue for glueing carpet on the trailer bunks. Never had it come off.
Lou C
agree with that above do NOT use epoxy resin, if you ever have to remove the carpet you will have to use an air chisel to get it out. Better yet, ditch the carpet, get the deck gelcoated and enjoy less of a chance of rot....
Voges123
Ok thanks for the responses,I did a boat before with new carpet an after some of the carpet lifted up or had bubbles I'd say.what's a good way to keep the carpet down
James R
If you use APAC it will stay down and stay in place as you work.
ezmobee
Third the 6700 from Home Depot. That stuff is TOUGH. When I carpeted my bow deck with it I messed up the size of my hatches. I needed to trim them down a little bit. I thought, "hey I'll just unstaple the carpet and peel it back a little bit and trim the wood and then restaple." WRONG. The carpet wouldn't budge at all. Ended up having to remake the hatches completely. So maybe it's TOO good? :p
http://www.homedepot.com/h_d1/N-5yc...splay?langId=-1&storeId=10051&catalogId=10053
Voges123
ok sounds good i got that 6700 carpet adhesive but its blue i seen the green one an the blue one hopefully it works the same.
Moody Blue
Not sure what the blue product is. Maybe solvent based? Only one I've seen/used is in the green packaging and it is water based.
