Re: fiberglass bondo
OOPS Sooper Dooper Peanut Butter Recipe
here is the forumula....
cabosil....glass bubbles and 1/4 inch glass fibers.....mixed with resin
mix it up well use a drill with an Old Hand Mixer paddle. Should be the consistency of creamy peanut butter.
after its mixed up good....then add the catalyst.....according to the amount of resin you added....between 1.5% to 2.5%...no more....no less
Mix it again
Apply You'll have about 15 mins @ 70 degrees less time if it's hot. Use less catalyst to give you more time but NOT less than 1.5%
