Mark42
- Oct 8, 2003
- 9,334
While fairing out the hard top, the fiber sanding discs tend to load up with epoxy and it ruins the disc for further sanding. This morning I went out to continue working on the top and saw a few discs loaded up that were otherwise not worn out. Thats about $2 a disc out the window. So I decided to see if they could be saved and took the loaded discs to the bench grinder that has a wire wheel on it and in no time at all, the discs were clean and ready for more sanding duty! Whoo Hoo! Saves me a trip down town and a few dollars in new discs.
This may or may not work with PSA (pressure sensitive adhesive) discs, or the hook and loop discs, because the wire wheel might tear them up. But it works great on the tough fiber backed discs. The wire wheel took off the epoxy but left the grit behind.
