Re: Fiber glassing cloth on dry wood 2 for 1 ?
Where'd you get a sheet of plywood that was 6 x 10, TG?<br /><br />For applying the resin, go to Home Depot and get a 9" paint roll that is made specifically for resins and adhesives. I even band sawed some of those rolls in half to use on my 4" trim roller. The 4" is a good size when you are doing other than full sheets.<br /><br />I would also thin the resin(epoxy) with 15% Xylene. Also keep your sheets out in the sun. A combination will give you the best penetration and the best rot protection possible.<br /><br />ps, It may take longer to cure, having added xylene, but you may be able to lay your cloth and wet it out before the first application fully cures. Most of it would have sunk in anyway.
