craze1cars
Thread starter- Joined
- Dec 26, 2004
- 1,822
I'm mid-swap. Summary of project: I got ahold of a 1998 Chevy truck with 210,000 miles on a mechanic's lein. The customer never paid for his new remanufactured engine that the shop just installed, so the shop took ownership of the truck and ended up selling it to me. I drove the truck around for a few hundred miles to break in the motor and confirm it's a good one (it is). And now this new reman 5.7L Vortec is coming out of the truck and going into my boat. The boat's 1999 Volvo Penta 5.0L PWTR Vortec (which is rather tired, but still runs good) will be going into the truck...and then the truck will be going off to auction
These are my questions:
1. Brass freeze plugs: Much to my pleasant surprise, the new reman engine already has brand new brass freeze plugs...EXCEPT for the large diameter one dead center under the flywheel. It is steel. Every brass freeze plug "kit" I can find has all brass plugs EXCEPT for this larger diameter one. I find this rather odd. WHY? Should I swap it for brass....if yes where can I buy one?
2. Exhaust manifold-to-head gaskets: Anything special or "marine" rated about this one? Seems to me I can use an automotive gasket here since water never touches it. Correct or wrong?
3. Intake manifold gaskets: Same question as above. Automotive Fel-Pro type gasket OK from my local parts store, or should I get one direct from Volvo?
That's all for now. Will ask again if something else comes up. Thank you.
