roscoe
Thread starter- Joined
- Oct 30, 2002
- 21,988
1986 Merc 115 inline 6.
Can't get gearcase off, or even loose.
Motor has been sitting a long time, and believe the driveshaft may be siezed to the block.
Don't have a lot of history on the motor, but it has sat for "a few" years.
Removed trim tab and the bolt under it.
Removed the front nut, the 2 under the anti vent plate, and the 2 side nuts.
Applied pb blaster to 3 front studs.
Been pounding on it for an hour.
Can't even get it to wiggle.
Can't even open up a gap.
I've removed these gear cases at least a dozen times, ok, probably 30 times, and while I have had some snug ones, they always came loose within 5 minutes.
I think it has been off at some point, because the trim tab bolt is not stock. Or maybe they just lost that bolt and replaced it with another.
Any ideas to get it loose?
