Re: Faulty check valves on oil injection system causing smoke?
Jim.
Thanks for the reply. I definately plan to replace the Crankcase pressure one- way check valve (part number #21-878105) the next time I work on the motor in the spring.
As it happens, I have three shop manuals (Mercury, Clymer, and Seloc) for my engine. Each one is a little different, so I like to read all three when I want to check something out. While they are all good manuals, I found that they were all somewhat deficient in regards to troubleshooting my specific problem. They all focused on troubleshooting symptoms where too little or no oil is being injected by the oil injection system. None of them provided much troubleshooting help when TOO MUCH oil was being injected. For example, the manuals didn't explain:
1) What is the normal PSI pressure level in the tanks when the engine is running? By knowing this, one could accurately test that the oil injection system is not being over-pressurized. Watching for a bulge in the reserve oil tank seems imprecise.
2) What component relieves pressure in the oil tanks when the engine is shut off? I have learned from this forum that it is the "crankcase pressure one- way check valve" and that this valve actually serves a dual purpose...... as a CHECK VALVE converting the crankcase pressure/vacuum cylces into positive pressure for injection into the oil tank (which the part's name implies) and also as a PRESSURE RELIEVE VALVE (which the parts name does not clearly imply).
3) How quickly should the PSI pressure in the tanks be relieved to atmospheric pressure levels after engine shutoff? I learned on the forum that this happens within a few minutes after shutoff. Before I knew this, I didn't know that the delay of several hours on my motor was an abnormal condition.
4) What keeps the oil from being pushed from the reservoir tank into the carbs and/or fuel line right after engine shutoff and before the pressure is relieved? I still suspect that the system is designed to prevent such a flow DURING THE FIRST FEW MINUTES AFTER SHUTDOWN AND BEFORE THE PRESSURE IS RELIEVED, but I am unsure which of these downstream components are definately involved and which are definately not involved (i.e., oil pump, 2 PSI check valve, fuel pump, carb float, and check valves on fuel line primer bulb.) Knowing this "definitively" from the shop manuals would have helped a lot in identifying or eliminating potential culprits contributing to my excess smoke problem.
Well, this is my rant on the service manuals in regards to troubleshooting an oil injection system that may be causing too much smoke. If it were not for the great information that I have gotten on this forum, I would have been lost...
Regards and thanks again to all of you who responded to my posts.
Hal
