Fastrak hydraulic Tilt issues 1999 225 Johnson
mhatho@msn.com
My first post so please bare with me.
I have a 1999 225 Johnson OB with fastrak power tilt/trim. While taking it to the lake the last trip, my transom saver came off the trailer and stopped supporting the lower unit. I noticed the motor bouncing and stopped to investigate. I noticed that the tilt ram was leaking fluid around the gland nut. The tilt and trim worked fine for that fishing trip. Once I got home I ordered a new rebuild / o-ring kit. I took apart the tilt cylinder and replaced the o rings, I also tried to remove the gland nuts on the trim cylinders and they wont budge at all, not with a spanner wrench or with a punch and hammer. I then removed all old fluid (which was grey and obviously mixed with water), filled it with new fluid and bled. The tilt worked great moving up and down and holding, but when motor came down to trim cylinders it would slowly creep all the way down. I then took the entire trim motor out and removed manual relief valve. The manual release valve smaller o-ring was actually broken and I replaced it. I also replaced the screen under pump, cleaned out old fluid again and put it all back together. Now the tilt doesnt work at all moving up or down. and when I lower the motor down to trim cylinders it again creeps down. I tightened the manual valve as tight as possible thinking this might be the issue, but again nothing. the motor sounds the same as when it was working. Does the entire unit need replacing?
mhatho@msn.com
Havent received a reply so going to try and clean it up a little.
TIlt doesnt work. Have replaced o-rings on tilt cylinder. Have not replaced o-rings on trim cylinders, because I cant get the nut to budge that holds cylinder in place. Replaced the o-rings on manual release valve. Is it possible that there could be debris in a valve inside pump? How do I get into, or should I even try to get into the pump? It has 12 point bolts inside it that I didn't want to mess with. I am desperate because a new tilt/trim motor is kind of expensive. It was working a lot better after first time taking it apart, tilt was working but trim didn't. AS I stated above, the motor sounds good.
mhatho@msn.com
Should the piston on bottom of tilt ram let fluid thru it when installing ram? I filled the cylinder up with fluid and when installing the ram into cylinder by hand, fluid pushes thru small holes on piston. I just took the entire pump apart, cleaned and reinstalled. Still won't hold motor, go up or down. Is it a bad piston or manual release?
