we-a-float
- Mar 5, 2017
- 5
Hey guys,
Have a 1993 Johnson Fast Strike 150 that will not Rev over 2500. I assume it is in SLOW mode from the research I have done. The motor idles ok, revs from a idle, but will not run over 2500. The stator, powerpack, pickup sensor, wires, plugs have been replaced. The compression varied about 10 psi between cylinders. Compression around 105 psi. Have spark from all 6 coils. I have disconnected the Diode, both temp sensors, lower plug from VRO to oil tank, all with same results. Pre-Mixing gas/oil. Carbs are clean, fuel pressure good.
Given the fact that the rpm is limited to 2500 and does not really vary from that, has me to lean towards a electrical ignition problem.
The Boat has been to two different dealer service shops the first could not seem to find the problem. The second stated that the PowerHead is causing the problem, due to compression, and needs to be replaced. I don't really buy that.
Wanting to get your feedback.
Thanks...
Thanks...
