Fast strike 150 pulse limiter
Bassinbob47
Hello. I have a johnson fast strike 150 j150glecd. My question is about the pulse limiter hose. The one that connects the bottom of the vro to the pulse limiter. Is it ok to use a regular 3/8 fuel hose for this or should I use the factory omc hose. They want $28 for that six inch hose. Thank you.
boobie
As long as it's not a preformed hose you should be able to get away with it. The trick is no kinks.
Bassinbob47
Excellent. The one that was on it was kinked pretty bad. Thank for answering my question.
