fast idle problem
73beetlebug
I have a 1989 140 Evinrude that had not been run in seven years. I rebuilt the carbs, new plugs, fresh gas, etc. I can get it running but only at a very fast idle and throttle pushed pretty far down. When I back it down it stalls. any help is appreciated. Thanks
Carbs not as clean as you think they are, carb adjustment not correct, or link & sync not properly performed. Link & sync is a far to lengthy procedure to type here so don't ask. Compression readings are what? A factory service manual is your friend.
