First of all, I just want to say what a great site this is. Lots of great info. I have a problem that I hope someone can help me out with. Used my boat this weekend and when I started it up the idle was faster than usual approx. 1100 rpm. Whant could cause this. Normally my idle is about 800-900 rmp even when first started on a cold day. Another problem that occurred is that after running about 10 mins @ 5000 rpms the overheat alarm would go off. If I kept the engine around 4500 rpm everything would be ok. I plan on changing out the t-stats and cleaning out poppet valve. My second question is, where is the poppet valve located? I'm thinking that a t-stat is stuck. Could a stuck t-stat make the idle faster than usual?
