Fast idle lever on 95 Force 120 does what?
1995120
New boat owner and new to the forum. Looks like my Force idle problem is a common one. I have a fast idle lever on my control box that seems to do nothing when lifted. Can any one tell me what it is supposed to do? Is it a mechanical or electrical control? FYI when lifted it will not allow shifting into gear. Thks
roscoe
Re: Fast idle lever on 95 Force 120 does what?
Fast idle lever should advance the throttle a bit.<br />No shift when lifted is normal, to prevent you from putting it into gear at too high of rpm.<br /><br />If you are not able to advance the throttle, you will have trouble getting her started and keeping it running when engine is cold.<br /><br />What brand or type of control box do you have.<br />Sounds like it is either older than the motor, or not specifically made for it.<br /><br />Most Force controls for mid 90's motors were Quicksilver Commander units. They did not have a lever, but instead had a release button to push, then you advanced the throttle lever.
1995120
Roscoe - thks for the prompt response and right you are. Mechanical action, figured it out this evening - I was simply not moving the lever enough to advance the throttle.
roscoe
Happy boating.
