convergent
Thread starter- Joined
- May 17, 2010
- 385
I just bought a '93 boat with Mercury 115HP. The controller has a flat lever on the top that the prior owner told me you lift up for fast idle. His mechanic told me that when I start it up cold, I should crank it for a few seconds, then push in the key for choke, and it should start up... then to lift the fast idle lever for it to warm up. I am not sure that I'm getting much difference in idle when I lift that lever. Should it be a lot higher RPM, or just a subtle change. Is there a way with this boat to rev the engine up in neutral more than this if I wanted to do that... not that I'd think this would be something I'd do often? I just want to understand how this lever worked.
