Fast Idle Adjustment 120 Force
pauldjasmine
I have a Clymer manual it tells you how to adjust the air mixture and idle adjustment on some models but on a 1998 Force 120 I can't seem to find any adjustment screw other than possibly an adjustment to the Throttle cable or linkage. Is this were the adjustment would be made to increase your idle speed? If so do I want to increase the travel or shorten it? Does this procedure also affect timing? Thanks
