I just recently purchased a new to me 1987 120hp Johnson outboard. Every once in a while when I go to start my engine cold and the alarm buzzer will stay on constantly before I even crank the engine and then stays on untill I get the engine warmed up. After 5-10mins of the motor running sometimes the buzzer shuts off sometimes it doesnt. I did some trouble shooting with the key turned in the on position and the buzzer giving me a false reading I disconnected the wire plug going into the vro oil/fuel pump and it the buzzer stoped! However, with the key still turned I went to plug the connector back in and it stopped buzzing altogether, key turned or not. My question is, did I fix it or not? Is it possible unplugging and plugging back in the connector maybe cleaned a connection? Or is there a more serious problem I am not seeing here that would cause this false alarm to turn on and off speratically?
