Falls back to idle at wot
Covemaster2019
115 mercury 4s dies back to idle after running wotbfor 1-2 minutes then picks back up to 5700 rpm wot and repeats
Welcome aboard
Most likely fuel system related. When was the last time the carbs were serviced?
The issue is still fuel system related
Since there are many variations of the 115 and you didnt specify
To help us help you, post your serial numbers and year
Do the basic trouble shooting per the manual
alldodge
First thought is fuel pump is not keeping up. I would look at a fuel line restriction or the low pressure lift pump
GA_Boater
Welcome aboard, Cove.
We do need more info about the motor. Having the serial number helps a lot.
When this happens, the throttle is wide open and the motor cycles from WOT to idle until you chop the throttle. What happens at other throttle settings? Say running at mid-throttle or 3/4's, does the motor eventually fall over to idle?
I would eliminate the external fuel system by using a portable tank with it's hose. If it runs OK, you know it's the motor.
