f60tlrc carbs
llgohde
i have f60tlrc 2004 yahama f60. I need new carbs and someone has a set on ebay for a 2003 f60tlrb i was wondreind if they are the same carbs
99yam40
Re: f60tlrc carbs
look them up on parts to see if they are the same #
What did you do to destroy your carbs that they need replacing?
llgohde
Re: f60tlrc carbs
the part number is 69W-14904-11 and my part number is 69w-14904-12. I was told the o ring on my gas cap was bad and it was running with water in the fuel, caused pitting in the carbs. runs great when full open but slow and idel is a problem. been sitting for over a year didnt have 2300 for the dealer to fix it. New jersey is to expensive for everything
Silvertip
Re: f60tlrc carbs
Idle and midrange passages in a four-stroke carb are small and easily varnished/gummed up. Before I bought different carbs of questionable condition and application, I would spend a few bucks on rebuild kits and try to fix what you have. I don't believe your mechanic. I would also suggest you install a water separating fuel filter if you don't have one. Again, not a budget buster.
99yam40
Re: f60tlrc carbs
you will more than likely get the answers on part#s on the other site
post the numbers there
