F150TXR and battery switch question
bear_69cuda
A quick question for you regarding my 2008 F150TXR.
I purchased the isolator lead to charge my house battery. I'm installing this switch to my electrical system (Blue Sea Systems Dual Circuit Plus Battery Switch 5511e) http://bluesea.com/products/5511e
In the rigging guide it says to connect the lead directly to the + pos of the house/aux battery. I was curious if this wiring diagram I made would work. (see attached) The switch above allows me to combine both batteries for start incase of emergency. Normally I would be running in on mode so both batteries would be separated.
I want to make sure if I needed to do use combine on the switch, the charging output, and the AUX isolator from the F150TRX would be safe in combine mode.
Thanks!
rodbolt
Re: F150TXR and battery switch question
your good to go.
dont forget the fuse for the isolator lead.
bear_69cuda
Thanks dude!
Yep, the lead I purchased from Yamaha has the fuse in-line..
rodbolt
wasnt cheap :).
but still cheaper and easier than battery combiners and such.
you wont belive how many hull manufactures and riggers have no clue the Yamaha 150 and up motors already have a battery isolator and have since the 90s.
