F115 low rpms, vibration, unusually quiet.
jerkin
Took my Yamaha F115 out for the first trip of the year and it's not running right. When you hit the throttle you don't hear the roar it normally has, almost like there is a muffler on it. It has a slight vibration and will tach out at about 4k (propped for 6k). Ran fine when I put it away. I pulled the plugs and number 3 was a bit wet so I replaced it, checked for spark and took it out again. Same problem. Any ideas would be great.
jerkin
Figured it was probably a vst issue so I did a pressure test at the rail and it shows 40psi. Left the boat tied to the trailer and threw it in gear, got it up to a little over 3000 rpms and it held 40psi. Not sure where to go from here. Pulled the number 3 plug again and it's still wet. Stuck injector? Thanks in advance for any help. I'm at the lake on my vacation right now, lol.
